1996 RCSB s10 LSX swapped roller
The truck is together and running right now but I'm going to pull the engine/trans and go another route.
Asking $2000 for the complete roller
1996 rcsb s10, notched/boxed frame for AC, relocated Fbody fuel tank (was 4.3/NV3500)
Ford Explorer 8.8, 3.73 gears and disk brakes (drilled for GM bolt pattern)
BRP 1 3/4" in frame LT headers, coated
BRP transmission mount
CPW plug and play swap harness
CPW poly engine mounts
Jegs aluminum radiator
Dodge Interpid dual fans
Aluminum remote PS reservoir
Homemade Cal-Trak bars
Racetronix fuel pump with hotwire kit
16" Camaro wheels with brand new Falken tires
Had a fiberglass roll pan that I never installed
It has a small dent in the driver side fender by the headlight
One of the wheel studs on the passenger side broke loose while I was changing wheels/tires
It needs a new windshield
Need to figure out where you want the fuel fill
The drain plug on the radiator stripped (easily fixable)
http://img.photobucket.com/albums/v6...ps2043e29e.jpg
http://img.photobucket.com/albums/v6...psefv1bdqh.mp4
