4l80e slip yoke
I need to know what slip yoke will work on my 80e
I seen the write up on performance tucks and he used his nv3500 yoke, but my tail housing is different. My yoke is 32 spline as well as the out put shaft and they engage together but the outer part of the yoke hits on the bearing just inside the case and won't let it slide on but an inch
So what one do I need http://i1013.photobucket.com/albums/...170241_856.jpg
You have to go to a new tcase at your local pick a part it cheeper and earier then changing out the iput spline. i got mine out of a 1990 suburban 3/4 ton. I also took the tcase adapter and used that one. it cost me 150.00.
Actually, this is a 2wd unit. I figured out that it had a parking brake attached for a heavy duty box truck or van.
I'm hopeing I can find a seal to fit, and remove the bearing.
