I have Tricks turbo kit on my truck but it doesn't really leave room for a breather coming out of the oil cap. What are you guys doing? I don't need anything fancy just something to get the job done. Thanks
Remove rocker cover.
Drill a hole.
Install fitting.
Put little filter on the fitting.
That's simple.
No PCV needed anymore?
i posted for a simple one.
Remove pcv hose and cap intake.
Put filters on both rocker covers.
The more venting, the better.
With your setup, i'd do it bigger. put som -10 or -12 fittings on the covers, run both hoses to a catch can with a filter.
Ok, thanks man. I havent got much time in on the motor assembly lately. It has crank and 3 pistons in lol. I did however paint clear and build the nv149 with the machine input shaft. If I can only have an extra 2 hours a day I would be set!
Not enuff hours for mods!!!
Thanks pretty simple and to the point, thanks! I'll to look into the -12 fittings and a catch can. Farmtruc I sent you a pm.
Never is enough time for mods but I still manage to make time...!:smile:
i did the boosted catch can from Mighty Mouse on ls1tech
http://img.photobucket.com/albums/v1...psb2557f66.jpg
