Anybody ever have a cam sensor issue? If so what problems did it cause
misfires, long cranking, loss of power, truck will run but has no balls, im going thru a cmp issue right now.
we've had a lot of trucks come thru with a cam sensor or wiring issue; non of them had loss of power.
the engine will run fine with no cam sensor; just hard starts; all the times we've seen.
they all had random extended crank; some start up fine randomly.
a code almost always sets; low ref, hi signal, cam performance etc.
maybe this will help garrison
what have you done so far, in attempt to fix it?
found a bad spot in the wire replaced it with a new plug and new sensor, this weekend im gonna chack the pcm terminals also, gonna strip it down to a stand alone, i think it is either wore out at the pcm, or there is trash in the cmp hole. i do know my patience is wearing thin lol, the MAF still leans it way out when plugged in, i need an SD like no otther.
