Need some turbo insight...apologize up front for any redundant questions
I am trying to get back in the game. I have a 92 swb that I have swapped a 5.3/T56 into.
Specs of the truck are in my sig.
I have always planned on adding a turbo, but life required priorities to be shifted away from the truck for a while.
I have no specific goal with the truck, but primarily enjoy doing things that aren't common on every vehicle you see driving up and down the road.
I would like to get to 500 hp + if possible, but maintain decent street manners.
I have been reading a fair amount, but the level of information is eye crossing, thus my questions.
-I have had in mind a single 70mm set up. I don't have a specific brand in mind, but lean toward magnum. Is there a particular trim, ar etc that you guys with some experience, would recommend.
-In the past a 40mm wastegate was recommended. Does that sound reasonable.
-what would you recommend for a blow off valve?
-will 100lb injectors be sufficient?
-truck has a walbro 255 which I expect to be ok. Am I correct in my thinking there?
-I will be doing the fab work myself. Is is necessary to run hot side exhaust into the turbo from both manifolds, or is one manifold sufficient?
Sorry for so many questions, and thanks for any responses.
I appreciate your time and input.
