Anybody ever used an OBS power steering pump on an ls motor? Can you even do it? My pump is burned up on my lq4 and was wondering if I could take the one off my TBI motor and put on it.
i wouldnt see why not as the motor is only there to turn the pully. so as long as you can fabricate a bracket or make use of the brackets you have by modifying them, it should work just fine as long as the pullies are lined up. obviously you will need a different size belt. if you make it happen, you should do a writeup about it.
Check out if there is an inexpensive rebuild kit for your pump. They usually just contain a bearing and o-ring seals. Not much that can break inside a power steering pump.
EDELMANN Part # 7910
