What kind of wire would I need to buy to build my own harness, and where would I find it? The one I have is a mess and want to clean up the engine by re-routing wires and relocating the PCM.
If u got the time for it then I congradulate you. You will be there for days rewiring it. Try getting a 2nd harness and use those wires to lengthen what needs to be. Then solder, double heat shrink with waterproof marine heat shrink tubing. Then tape up wires with good quality electrical tape and wire loom.
Good luck on your project, if you need any pigtails, fan harness, ect. feel free to contact me via email at "roy@nelsonperformance.com" or give us a call at (210) 626-0278 also we offer a show quality engine harness if you are interested in purchasing a new harness
You can use 18ga priary wire that can be found at napa.
