PRND indicator question...
ok so i have searched and there are a few threads on how to hook it up but i dont fully understand.
yes i have the swap in and running. everything worked fine from the get go with the starter and tranny as i deleted the wiring from the stock harness and used the plugs from the harness that came with harness from the motor (7pin and 4 pin) obviously my indicator light isnt working as there is no signal going to it.
my question is, WHAT EXACTLY TELLS THE DASH WHAT LETTER/NUMBER TO DISPLAY? i havnt found anything on the net that explains how the circuit works and i was hoping someone knew and could explain a lil more in detail.
from what i gather, the signal is from the 4pin connector that goes to the pcm and the pcm then tells the dash what to display. my confusion is that there is only 4 pins.... and there are 7 led's that light to indicate the gear.....
does the prindle switch send a combination of signals to the pcm which it deciphers and tells which led to illuminate? thats the only way i can see it working. if this is not it please enlighten me!!
my problem is that i unfortunately cut the wires from the old harness thinking i didnt need them... well if i want the light to work (which i do) i will now have to find them and hook them up somehow. do i just find the 4 wires and "piggy back" them to the LS 4 pin connector and that should make the light work? or is it just one wire i need? or two..etc???
the other problem is that the escalade diagrams show pin numbers for the pcm but the obs diagrams dont have pin numbers and there are several wires which are the same color.... how to i go about picking the correct wires from the old harness to hook back in? does anyone have a pinout diagram for the obs pcm???
i opologize for the long post especially if this has been covered but i cant for the life of me find it! it would be great if you could tell me how to hook it up but i would REALLY like to know how the circuitry works if possible. thanks!
