Is there a sensor in the tranny for that value? Also I am wondering if I were to get a gauge cluster from a Denali like the one here and hook it up without anything else, would it work?
This is for an 02 GMC Yukon XL. TIA
that cluster should work on your truck, and the tranny temp will work on it with no extra wiring. plug and play :cool: for that price i would upgrade to the escelade instrument cluster. you can find good deals if you keep your eyes open.
i put in an autometer temp sender right in the pan works fin no leaks..
Technically speaking, there is a trans fluid temp sensor built into the tranny. It's part of the fluid pressure switch assembly. The trans temp gauge in the Denali/Escalade cluster is using output from that sensor.
Guess GM didn't think us poor slobs, who can't lay out the $$$ for a Denali/Escalade, would find that information useful :whack:
just get an autometer for like 40 bucks works fine
