Well, my Transgo and other trans pieces are in; along w/ a retune from Allen. After driving for about week, the conclusion is that the 1-2 shift is just a little to radical for an old codger like me :smile: Seriously, any 1-2 shifting over ~2500 RPM is seriously hard and tire barking. At WOT that may be great, but trying to merge into highway traffic w/ the tires trying to break loose is just not good.
Along w/ a Sonnax Vette servo, I used NO TG spacers in the 1-2 accum and drilled the 1-2 feed in VB plate using the small bit. So you guys planning to do this work, BE CONSERVATIVE. Now, if you want eyeball popping, teeth jarring 1-2 shifts, then go for it! :rock:
Overall i really like the results. Allen did a great job on the retune. The positive effect of that servo release check valve is really noticeable for both 2-3 and 3-2 shifting. Very nice.
Just talked to Allen a bit ago and he's going to tweak my tune a little to reduce the 1-2 shift hardness. Something about shift delay. He's going to do what he can to prevent me from going back in to make mechanical changes. One of the reasons many of us use Nelson: Customer Service :thumb:
