How is every one playing with this style truck doing your gauges? Can this swap work with factory or do I need to look in another direction?
I'm doing an 03 4.8 drive by wire and 350 th trans.
You will simply need to adapt your old sending units to the new engine. I believe the engine temp and oil pressure are the only ones that will need to be adapted.
Assuming you have a V-8, your engine temp sender is on the driver's side cylinder head between the first and second spark plug. The oil pressure sender is behind the distributor. Adapters are available for each since the LS engine is metric and the Gen I small block is standard.
There was a thread on here about turning down and rethreading an existing temp sender to fit the LS's smaller hole for the temp sender on the rear of the passenger side cylinder head.
Damn. They had after market gauges for both of those. Ill have to buy em but that info tells me a lot thanks. Any idea who Carey's the adaptors?
