Just debating wether or not this will allow enough flow for the turbo. Just where the crossover merges with the passenger manifold then to the turbo(too small of a diameter??). its a 72mm Magnum .96Ar. Thanks
Some may say yes and some may say no but I'd go a different route if I were you.
Well where it joins up its almost 3" then it transitions to 3" then to the flange. What size pipe is typical?
That is going to flow great!
The kit will outflow the turbo!
That looks about a 2.5" hole or so, if so; don't look back and move forward!
you'll see how linear and well it flows when you're done!
my kit on the avalanche wasn't exactly like that, the merge was between the turbo and flange, like a Y pipe (which yours is too); that big thing made 525hp on 11-12psi, Magnum 76mm, 48lb inj, walbro pump (stopped pushing it when fuel pressure started dropping), oh ya and the 6.0L i think, maybe the 5.3L i can't remember and don't care, lol.
Point is, you'll enjoy it.
Just what I needed to hear man, Thanks alot!
It will work just fine but you will want a bigger turbo! 80MM to start with!
