Turbo Build?
im hopefully going to be closing the deal over this year with a new turbo set up. i currently have the truck sitting in the garage, with the 4l80 and new multi disk in it awaiting for a new drive shaft. below is a list that im shooting for in the next year since i got my new job it could be possible. ill list the mods in the order of what i think ill do first please put in any input and toughs you all might have thanks again.
1st Rear end- 3.73 Gears - stock , and soon Tru-Trac
2nd Fuel- walbro 400, 83lb Siemens DEKA Ev1 injectors
3rd Tranny- Rebuild with a shift kit.
4th Gauges- Thinking Plx boost and Fuel pressure gauge?
5th Turbo- Trick Stage 3
6th Meth- Trick performance 1.5 gallon tank, DVC-30 Meth Injection stage 2 kit, from Trick Performance
also with my cam, and heads do you think it would be possible to hit 11's on 11-12 psi?
Ya. Leave the in there until you see the results. Then swap it if needed.
sounds good as far as the cam goes :)
Flow master in your sig. Needs to go away for the turbo build.
Go with a straight Perf core design.
ya im planning or running a magnaflow prob a duramax exhaust set up ::)
