I have found some info on wiring the speedo and cruise to the pcm but how does the abs get its signal from the pcm if i get rid of the drac box? Does it read the same pulses as the speedo and cruise or different pulses? Thanks
The ABS system is all to itself.. If you are using an aftermarket stand alone harness the Speedo wire can be ran directly to your cluster... I would have to double check with my friend on the cruise control wiring........
Please let us know, I am doing a 5.3 swap into a 95 as well and was wondering if it was really this simple:
http://www.ls1truck.com/forums/showt...558#post131558
the abs wiring in my truck right now is connected to the buffer box which gets its reading from the transmission. If i wanted to delete the buffer box I need to know where the trans signal is gonna come from because i dont know what the pulses on the signal is
