wiring harness help
im working on removing my 97 5.7 vortec engine
im going to replace it with a 5.3
need a little help fellas
what size screw is holding the connector for the wiring harness on the driver side?
i can feel something but i cant see it
also how do i remove the beige connector on driver side
i have pried and pulled but no dice
thanks
Just cut the harness lol, you are going to be swapping over to a different setup anyways
MrHorsepowerLSx makes a good suggestion to cut it, out of all the wires on there you will only be integrating a few of them back to work with your factory gauges. Removing it is not that hard. In the center is a tiny 1/4" bolt that holds all the sections together (if yours is like mine, which mine is a 94'). I cut mine about a foot back from where it enters the drivers side firewall for future intergration and left the rest of the harness intact and removed with the engine.
Here is where the cluster enter the firewall next to the brake booster.
http://i1049.photobucket.com/albums/...1358782804.jpg
Here is what the 1/4" bolt looks like that holds it in place. The bolt is recessed into the center of the cluster and can be hard to see. Just put a 1/4" socket into there and back it out.
http://i1049.photobucket.com/albums/...1358782800.jpg
If you need an unmolested LS truck harness with fuse block and dash harness and PCM the whole shibang I have one for you harness and PCM are from 2000 silvy
personally i wouldnt cut anything. figure out how the connector comes apart
Ever figure out that connector?
mine is a 95 and was a torx bolt unsure of the size though
Yes it is a torx and the bolt is fairly long.
