I'm wanting to pick up a set of 315/45/16 radials for my truck and was just wondering if they'd fit up under it and not stick out a million miles or rub my frame with my stock width rear end?
Why soo much meat? Going for bigger build?
They should fit with ease had a set on my 01, even had 315's on my Camaro that didnt rub lol
They will fit fine. Garrison and simon and shawn. Have all ran that same setup
With no issues
What kind of offset should I get on my wheels?
How much power u putting down? Just because the 315s are wider doesnt mean they'll hook any better there like 27" tall aren't they? I use to run them but on a car still had issues hooking best tire in a 16'' I loved that hookes better than the 315s was the 275/55/17 just sharing my feed back on them 315s
No wider isnt better hints my first comment. Rotational friction does work against you when over done. Thats tbss guys problems they go wide as phuck and slows them down... I suggest try the 275s in a mh DR or dot legal slick.
http://www.stangtv.com/tech-stories/...-drag-radials/
Lots of good info here
