corvette servo stuck inside transmission :(
so i ordered a new corvette servo from OPT and it got here today i took out my old one and put my new one together i followed the directions to a T and went along with the video i found on here to make sure i did it right. i made sure the snap ring was seated in its grooves over the cover i went for a test drive around the block and noticed it wouldnt shift into second gear (light throttle) i figured i did the newbie thing (considering im 19) and didnt have the snap ring on all the way i stopped looked and the cover was intact and not leaking i got back in drove back home and gave it half throttle to see if it would shift under more pressure it did after a while of floating around 3500 rpm when i got back home and looked the snap ring was almost off and the cover was loose. i took the cover back off and the 4th apply piston Teflon ring looked kind of blown out like fluid got underneath it or something. i lubed everything up with tranny fluid but now the pin, inner housing and second apply piston are stuck in the tranny and i cant get them out. someone please help me!! i appericate it!
