hardware question
I was wondering if its possible to swap some arp rod bolts into a motor, without pulling the motor, and just removing the oil pan ?
I'll be doing this when I have the 60e pulled and before I put the 80e in. Also will be using a lift.
Now another question, should I replace the flywheel and convertor bolts, with some a bit beefier while I'm in there ?
Yep it can be done, drop that crossmember thats in there too. Follow ARP's instructions, and use a high quality torque wrench. I replaced my flywheel and pressure plate bolts with ARP's. Just because. Nver heard of stock giving out though.
