It only kicks on for like 2 Sec an gose off?? An dose it a few times I have 06 fan Nelson harness
Email jon@nels... And he will call you.
I'll make him aware of the post.
In the meantime do this so you will be a step ahead.
Ground the blue wire. Both fans should turn on low speed.
Apply 12v to the green wire. One fan should turn on high speed.
Now do both like mentioned above for each wire. Both fans should turn on high speed.
Ok ill try it
Mine does the same thing, one comes on high when AC compressor is on. The AC compressor cycles a lot.
Mine is like on for a Sec or 2 than off an back on for a Sec back off with ac off. I checked all the word thought one could have a bad connection but there all good
Compressor runs if its on defrost or recirculate also, no matter what the button on the dash says. Other than it going with compressor I couldnt tell you what to look for. Good luck.
When I ground the blue wire nonthan happens?
I called him back an he took care of me!
