Trick Performance All in one Nitrous Controller
SOLD!
Im putting my Trick Performance Nitrous controller up for sale because i no longer need it. This is complete never been used before unit. Its a window switch, progressive controller, bottle heater controller (turns bottle heater on and off between set pressures) Air/Fuel gauge (will shut nitrous off if it goes to lean/rich), shift light, first gear lock out, and much more. This includes everything needed for the A/F setup including a bung and o2 sensor. It includes all the wiring that come with it and instruction manuals along with the 1600 psi sensor for bottle pressure control/display and a -6 adapter if you want to put the sensor in the feel line instead of the bottle. The only thing is i mocked the gauge up in my center console at one point and cut the retainer bracket in half but it will still hold the gauge securely in any gauge pod. Looking to get $550 plus shipping as this is a unused unit and is no longer made.
http://www.trickperformanceproducts.com/tpp_00019.htm
Im not using this because it turned out all i wanted was a window switch so decided to sell this and buy a regular window switch
http://i25.photobucket.com/albums/c9...IMG_0127-1.jpg
http://i25.photobucket.com/albums/c9...IMG_0128-1.jpg
http://i25.photobucket.com/albums/c9...e/IMG_0129.jpg
http://i25.photobucket.com/albums/c9...e/IMG_0130.jpg
http://i25.photobucket.com/albums/c9...e/IMG_0132.jpg
http://i25.photobucket.com/albums/c9...e/IMG_0133.jpg
