Looking for rear axle assembly to do the 14 bolt swap. Gear ratio doesn't matter but need it to be 2006 up rear end.
Get with whiteout ( Israel)
Why 06+?
FYI the 05-06 rear is hard to come by replacement parts as in axles. I snapped an axle and had to go thru GM to get one and it was 305 for a single one. I tried Moser and they didnt have any stock that large. SUperior doesnt make any nor do others
If i was to do it again, id go 9"
I hear ya but don't have the coin for a 9". Might even have to build the 10 bolt if I can't find one or it's too much. What's good price for used one?
if you resort to using a 14bolt use one from a GMT400 truck. axles are more available. just have someone move the perches
i paid 1400 for mine back in 06 had 1k miles on it
Find a 9" from a junk yard for 50-100 bucks. then upgrade the parts. You might get lucky and find a fullsize ford that has similar width as your truck. this might be best route, you can also get a backbone brace cheap as well. If you can weld youre golden. Its possible you could have less then 1000 into it. [depending on how you go about this]
Dutchman makes replacement axles for the 14bolts.. Been running some in the TBSS for a while now.. Good parts
