Originally Posted by
flattopwill
Hey all. My truck has a P1810 DTC which is for TFP switch malfunction. Has had this since I put this motor/trans in. I took it to my trans guy to hook up his scanner and drove it and he said the switch is functioning properly.
Symptoms: Between ~40-55mph with light throttle the TC will lock-unlock rapidly until I change throttle position. Also, it stumbles and chokes a lot when at low speeds (like parking) when the CE light is on but acts fine when the light is off.
Notes:
I had Nelson change my lockup mph in 4th to 40mph.
Occasionally the TC wont lockup above 55mph either.
Occasionally the TC works perfect at all speeds.
The TC is a 9.5" RevMax 2800rpm stall converter.
The pressure switch was replaced when the trans was installed 3/2010.
My trans guy said I should have Nelson just remove the code from the computer altogether.
What do you think?!
