Atomic's Christmas Sale
I can get pics of everything if I need to. Everything is OBO + shipping and fees, but pm me and we can work something out.
TR 224-112 - 224/224 .563/.563 112 LSA cam, excellent shape, has about 15k on it. SOLD
OEM 3.73 8.625" (10 bolt) Ring and Pinion gears, 150k, SOLD
Yukon 4.56 9.5" (14b sf) Ring and Pinion gears, 20k, $100
L92 intake gaskets, good shape, $25
L92 fuel rail, good shape, $50
L92 intake, bare, $100
L92 intake cover, $60
Pro-comp traction bars for 99-07 with install kit and all hardware for halfton. $250
99 blue center jump seat, lid is broken, $20, dont want to ship
99 water pump (minus fan), works fine, $40
99 coolant res, $15
99 vacuum brake booster, $20
99 5.3 radiator, good shape, $50
99-07 ac compressor bracket, $20
2 sets of rear 2in lift blocks from a stock 4wd, $20 per set
set of rear ubolts for stock 4wd, $10
4l60e -6an cooler fittings, brand new, $20
99 fuel lines w/filter complete from tank to engine, $100
99 stock transmission cooler lines from trans to rad, $50
99 ypipe with cats, uncut, $150, dont want to ship
99 catback exhaust with what looks like a flowmaster 40, I will cut off the muffler or connector if someone wants it, $25 for both?
99 reg cab short bed 4wd rear driveshaft, $60
07+ rear wall carpet and insulation, grey, good shape, $50
99 complete fuel pump assembly, works, $60
99 stock cluster (100mph), works but has a crack in the bottom left of the plastic cover, SOLD
99 complete intake tube, airbox, and maf, $60
Just added:
99 power steering pump, works fine, $50
2 sets of stock plug wires, $15 per set
4l60e to 4l80e 4wd conversion crossmember, SOLD
4l60e transfer case adapter w/bolts, $50
4" mandrel bend 180deg exhaust pipe, brand new, $40
Oil filter sandwhich plate (red) for an external oil filter, never used. 2wd only, on 4wd it hits the driveshaft. SOLD
Oil filter sandwhich plate for monitoring temps or a turbo feed, barely used. SOLD
http://i11.photobucket.com/albums/a1...2983Custom.jpg
http://i11.photobucket.com/albums/a1...2985Custom.jpg
http://i11.photobucket.com/albums/a1...2987Custom.jpg
http://i11.photobucket.com/albums/a1...2580Custom.jpg
http://i11.photobucket.com/albums/a1...2206Custom.jpg
http://i11.photobucket.com/albums/a1...2984Custom.jpg
http://i11.photobucket.com/albums/a1...2989Custom.jpg
http://i11.photobucket.com/albums/a1...2991Custom.jpg
http://i11.photobucket.com/albums/a1...2992Custom.jpg
http://i11.photobucket.com/albums/a1...1997Custom.jpg
Forgot about this little guy. Perfect for anyone who needs a simple turbo feed. Tapped for 1/8npt I believe, fitting is -4an. $25 shipped
http://i11.photobucket.com/albums/a1...0284Custom.jpg
what? no kitchen sink?
are those a/c lines i see in the 5th picture down?
If I had a spare one it would be for sale :lol:
Yes. Unfortunately my hot pipes interfer with the older style ac compressor so I dont have the ac hooked up right now. I want to eventually get it working though so I plan to keep those lines.
