what is the best spark plug to run in a 6.0l with a .224 .230 .581 .592 114lsa cam and minor bolt ons and 150 shot of nos. and will my stock 4.8l fuel pump give the motor enough gas or do i need to put a aftermarket one. PLEASE HELP
I would use NGK TR6's. I posted a cross reference response awhile back over to the NGK Iridium plugs. I'm sure they would be sufficient also. Remember to retard your timing 6 degrees for a 150 shot when you spray. Rule of thumb is 2 degrees for every 50 shot. Are you gonna spray wet or dry? :nx:
what do you mean degree my timing. and it is going to be a wet nos kit
I would have some type of retard module to retard your timing when you spray. MSD makes one. A wet shot sprays directly into the manifold and a dry shot sprays before the MAF.
