Looking for a better spring, I have v6 springs on my truck and with all the weight reduction the front end keeps getting higher. Truck is in the 3500lb range so I need a softer spring set up, any inputs welcome.
look into what s10 springs measure up to, ive read about 5 yrs ago ppl using springs from a chevelle on the front
Thanks, ill look into that
get some made...?
Softer or shorter?
I'm wanting two effects with the new springs. Softer to loosen the front end up, and lower the front a bit, prob still need to cut them down to get back down to normal ride height.
If you cut them it shortens the total coil, thus stiffening the spring. Maybe try the old torch method.
