Ok we are installing a fuel injector driver box for these 96lb low imp. injectors. In the tuning table do you still put in the flow rate they will be at our psi. Or is there something different we should load due to the driver box.?
I am coming up with my 96lb injectors are now 112.75 @ 60psi. This is the base psi we will be starting at.
Any help is appreciated.:)
Rick
