I'm just about ready for a set of cylinder heads to top off my 370ci build.
I'm offering $350 with valves.
We might have some at the shop...I'll try to remember to look.
which valves you plan on running? ls3 or l92 valves? they are different and it makes a huge difference specially in the rpm range. if i were you i wouldnt worry to much about stock valves, you'll need some good after market valves like ferrea or something to your liking, you got a good build dont cut yourself short ;) sorry have no intentions to disrupt yor wanted post , just letting know since i use the ls3 heads myself ;)
350 sounds low I'd say 500-600
350 is fair for used heads. And the LS3 heads are probably the route i will go. If i don't find any right now.
Good luck finding rectangle port heads for 350. You can't even get a set of 243s for that normally.
New the bare casting L92's are around $400 each from SDPC....just saying.
