my heads are decked .025" and i believe i found the new cam i am wanting to get..
the 228-228 has a valve lift of .588 will i have enough clearance in between my valves and pistons???
could i go bigger and still be safe, if so how much bigger?
anyone???
It depends on the valve events. Chances are you'll be fine though. Clay the pistons, assemble motor, turn it over a few times pull the head and check the clay.
I have stock heads with a .609/.604 lift cam and its just fine.
ok... i think i know what ill do.
you'll be fine
