lifter tap after cam install.......need help
First off my trucks got 150000 miles on it and i just installed a new tsp224r cam, 7.4 pushrods, comp 918 springs, new factory timing chain, and factory oil pump. I ve put about 400 miles on the new cam.
It started a few days ago a started my truck in the morning, cranked fine just a little tap from the stiffer springs like normal, let it warm up for about 5 to 10 minutes then headed off to work(about 8 miles) just befor i got to work it started tap pretty good, pulled in the parking lot at work let it sit and idle for a few minutes and it never quit tapping. let it sit till i drove it back home for lunch didnt have any problems, then let it sit till i had to go to school at 5:30, cranked it after class, everything was fine, but on my way home i stopped and got somethin from the hamburger joint and it started again, sitting in the parking lot it never quit for like 5 minutes pulled back on the hwy got going and it quit.
im thinking my lifters might be getting clogged up due to the miles on the truck and with the new srpings and the cam they just cant keep up
i going to run some bg cleaner through the motor and change my oil tomorrow and see if that helps.
