ppl have reccomended a cam... what cam should i get with what i have ???? ,......stats below
metalmulisha, What are you looking for? A stock idle stealth cam or a heafty lope? You can get pretty much the same HP out of either one depending on the grind.
Since you're 4x4 I'd look at a custom grind like so...
214/214 (268/268) .535-.545 112LSA Very strong low speed torque and would pull to 5800-6000 making power there easily. Have nice idle, decent chop.
Stock exhaust flows great as do the heads so I don't really see a need for a dual pattern cam unless you're trying to gain overlap or something of that nature.
sounds good that is def in the near future
