Stall out problem.
As of lately my truck has begun to stall out in the mornings, and after slow turns with the wheel cut to a side. It will literally stall after I come to a complete stop then go to accelerate. I made sure my accesories were off and it had still done it. Turned my radio off along with my defroster, and once I go to accelerate it stalls. Any suggestions. I am going to replace my alternator and battery because I have not done so since I have owned the truck. One of my friends suggested that it may be stalling due to strain on one of the pulleys actually causing it enough strain? Any suggestions are helpful.
Maybe a fuel pump problem? Does it still do it with a full tank?
i don't think it has to do with the fuel pump. It cuts out at different fuel levels.
How does your power steering feel? Fluid level?
The rack is seeping a little bit but not horribly. I am going to replace it because my inner tie-rods are worn. Fluid level seems fine though.
What year is your truck? Try cleaning your throttle body.
