Well I put a 2800 stall and i have everything finally set the way i want it. The only thing is I keep getting po3000 since the converter. Does anybody know which table in the misfire category i have to change so i wont get a false misfire reading.
I had to do that on mine too.
go to
Engine diagnostics-> Misfire-> Revolution mode
Low RPM and High RPM are already maxed stock. Adjust Medium RPM
Cylinder Mode
High RPM is already maxed
Adjust Idle not moving and moving and Medium RPM.
Once you open those tables you will notice there is only a small section that is not already maxed. That is where you need to make your changes. I just doubled those values and then started pulling them back towards stock in 10% increments until I got the codes again and then went back up 10%.
Some people just max them all out, but I would rather adjust the code rather than eliminating it.
OK thanks a bunch, ill report back tomorrow with results.
Edit: ok got about 50 miles on her since the update and so far no codes. Thanks for you help, I couldn't even find that answer on EFIlive.com.
Do you have Hp or efilive.
I have HPtuners, so if you are working with EFIlive they may have different names on the tables. Should be the same settings though.
But if you aren't getting the false misfire I wouldn't change them.
