Fuel line options.... new return or new feed? Dual walbros.
Alright i'm ready to put these walbro 255's in and cannot decide what to do... I am thinking of running a new 8AN feed and using my existing returnless "feed" as the new return line for purposes of keeping my factory fuel composition sensor to keep the ECM happy for E85 use. I'm going to be at about 12-14psi on 75lb injectors for right now. Would i be better off using a bulkhead and running a new feed and using the current feed as the return after the regualtor.. or should i run a new return line and use my existing feed? the line going into the composition sensor is the same as the line.. but the line coming out of the composition sensor is very small! looks like a serious restriction to me. I'm sure someone will say use the EVAP line as the return... but i hear a good many stories of tank pressure and venting problems. I Have even contemplated keeping the system returnless and running the second pump off a hobbs switch, so as not to heat the fuel when all that volume isn't needed... Thanks in advance for any help..... this is really beating me in the head! :smash:
