trans swap 1996 4l60e out of a 4x4 surburban put into a 1994 chevy z71 question?
ok i took the trans out of my 1994 z71 4l60e 4x4 m30 style (solid piece case transmission because the transmission housing was cracked at the adapter and leaking trans fluid alot)...... for a 1996 4x4 suburban 4l60e m30 style (solid piece case transmission).....
i put the torque converter out of the 1994 4l60e into the 1996 4l60e transmission
everything bolted up exact.....
the wiring harness in the 1996 4l60e transmission wiring has a extra connector end on the wiring harness ..so i swapped the electrical harness out of the 1994 transmission to the 1996 trans...and removed the extra solenoid from the 1996 trans...everything looked good and fit with no probs .. im having issues with the 1996 4l60e trans shifting properly........
so im thinking i need to swap the complete valve body form the 1994 trans to the 1996 trans to solve the shifting issue.....i(t goes into reverse and all foward gears except overdrive right now.)
is the casting on the transmissions the same at the valve body location of the transmissions?
will the valve body from the 1994 4l60e fit on the 1996 4l60e trans?
i want to swap the valve body from the 1994 trans to the 1996 trans
