best valve springs
Im starting to gather stuff for my cam swap and and was wanting to know what everyones opinion on the best valve springs? whats the best you've used, lasted the longest, most piece of mind running them? the cams probably gonna be a Texas Speed 220/220 or something in that range.
im running patriot dual gold springs!good up to .650
I got that cam and got the kit with it. Came with springs and pushrods. Got bout 5k miles and no problems.
Patriot extremes here. Cam is .609/.604 lift and ive put about 6500 miles on them sofar and they haven't skipped a beat.
Check out the Lunati dual spring kit, their answer to patriot golds. they are really nice springs.
what springs do yall offer with yalls cam package?
I have always run patriot dual golds in mine. I put over 10k on a set before. When pulled off they werent worn at all and prob could have made double if not more being that cam was low lift. I want to say the tsp 220 is lower then .600 lift
I'll be running the patriot extremes
Another here with patriot dual golds. About 30k on them and made 520 rwtq without a problem
