my yukon is leaking coolant very badly and ive replaced the thermostat and seal and waterpump gaskets in the past two days an it has not helped. i inspected the pump and found no visible cracks or anything out of the ordinary. its deff leaking on the motor side of the system the belts are getting soaked and i can get under and see it running off the bottom of the water pump but cannot find the origin.i know if i take it to a shop they will rape me in parts and labor but i can afford to keep buying gallon after gallon of antifrezze. when it drips its more on the passengerside of the motor but i believe thats from where its running across the bottom of the pump.
