Originally Posted by
Mangled03gmc
			I agree to sand it before paint, however , I think 400 is a lil ruff. I would start by hitting it with 5-800, just to haze it, open up the plastic some.. Then wipe it down good with alcohol, paint thinner.. If you have a tac cloth that will work after you clean it with the cleaners.. Paper towels work extremely well also.. Spray it with the paint your going to use.. Do however many coats you feel you want to do. Make sure it is even, spray the next coat while the previous coat is still tacky.. Once you have finished that, let that tack up, hit it with clear. Do the clear the same way as you do the paint, for however many coats you want.. Then once that has dried, hit with 2000 paper, water.. Go even with the strokes, keep the paper wet.. Then you have to buff it.. Buff if on low speed like 14-1700. Do not get it hot, always pull away from the edges.. Use a super super fine or even a finish cut.. Spray paint clear is a little softer then the good stuff.. I have done out board engine covers, valve covers, all kinds of things with rattle can paint it has turned out like a job I have done out of a gun. Prep is key to painting, not rushing through it.. vIf you would happen to get a run, let it dry and just sand that area out, then hit it with another coat of paint or clear.. Prep and finishing is where it as. The stuff in between can be persuaded some
