Truck:
2006 Sierra with a 5.3
Issue:
Cooling system does not hold pressure
Steps taken to fix problem:
New thermostat
Bled air from system
Taken to stealership, only for them to claim it was "normal"
Truck:
Issue:
New thermostat
Did anyone start with the simple stuff, like checking the pressure cap? Is there a visible coolant leak? Smell? How could a thermostat contribute to the system not holding pressure? Hope the Stealer didn't charge anything.
I hate to ask stupid questions but how do you know it isn't holding pressure are you using a pressure pump which goes in place of the cap. Perhaps you are going by the pressure after warming up. You haven't given us much to work with here. I assume you have verified that pressure is being lost not being cancelled by contraction from cooling. I will be glad to help if in fact you have confirmed the loss of pressure. The thing about cooling systems which lose pressure they show up pretty easily by doing a pressure test with a known good test set.
shane
Methinx this thread....is ded.
