Im a noob to LS1truck.com and I have a noob question, I just roasted the trans in my 03 Suburban and found a brand new transmission for a 2009 Silverado and was wondering if it will work in my 03?
I cannot gaurantee that it will but 99% of what I know about them says they will interchange.
Wish I new for sure...this trans is in the GM crate and has a very good price. Anyone else have any input on this?
I'm with Greg, 99% sure but not 100.
physically they will fit.
i know they have a second vss to determine input speed.
also park/neutral switch is inside of case instead of being on the outside like the old style
I'm going to say no. The 09 units have some internal changes on the valve body and internal wiring. The pressure manifold switch has been removed in 09 and your tcm I believe is looking for inputs from it. Also the prndl switch is now in the trans so the main case connector has added pins. I think you may not be able to plug it in. Vince
:grr: to gm for changing things without changing the name it it. Should b a 4l60n or something with that many changes.
