		Missifre
		Finally got my new 6.0 running and I think it has a missfire.  It runs pretty rich (you can smell it, and once I saw a flash of blue flame coming from the pass side open header.  It has new NGk plug, and msd wires.  I did a compression check just to make sure it was a mechancal problem and got 175-180 psi the cylinders.  Where should I start in looking for my miss and how should I go about doing it?  Please any advice would be appreciated I really want to get my baby back on the road terrorizing the neighborhood.:confused::confused:
		I'd start with o2's. I just went through a very similar issue and that's all it was.
		02s are cheap so I will prob try and pick some up this week and put them in and see what happens
		Sounds like you may only need one side. Pull a plug or two on on each side. I bet your passenger side is pitch black.
		just noticied that I never left a reply here after fixin the truck along time ago, and yes it was the 02 probably damaged it trying to  get the exhaust out from under the truck sorry so long
