It was under the dash of an '06 Silverado HD 2500.
http://i325.photobucket.com/albums/k...un/aaaw001.jpg
that is a BCM (body control module) it controls everything exept the motor and transmission ie. locks windows lights ect.
Thank you for that much. Just to clarify, do you, or anyone, know if it has anything to do with the ABS? And if so, what?
yes it does, it has inputs/outputs for the steering wheel position sensor that run to the abs unit. If you ditch the bcm you will lose abs
