How exactly does one interface the wideband with the laptop using HPT?? Specifically how do you connect the signal output wire from the wideband to the laptop. I doubt you just jam the wire into a USB port :LOL:
Depends on whether you buy the PRO interface or not.
http://www.hptuners.com/forum/showthread.php?t=2924
So I'm assuming that there is a module you plug the wire into to read the signal from the wideband
This adapter plugs into the side of the interface...
http://www.hptuners.com/images/p_eioplug.jpg
This is one of the preferred setups for the price...
http://www.ngk.com/afx/
http://hinsonsupercars.com/p-946-ngk...eband-kit.aspx
