Custom Grind Cam Spec sheet
What do u guys think?:ugh2:
Vehicle info:
Year/make/model: 08'Chevrolet Silverado reg cab
Weight With Driver:4520
Intended use:street/strip
Percentage of street driving:100%
Preferred shift rpm:7,000
Desired red-line:7,200
Idle/street manners: hard lope
Must this vehicle pass emissions? No
Maximum desired lift with new camshaft (very important):between .600-.650'
Reason for new camshaft (be very specific):
no 2nd guessing
Previous Camshaft: (specify stock if unmodified)stock
Manufacturer:
Specs (duration, lift, LSA, advance):
Duration at .006”,.050”, .200” if known:
Engine Details: (specify stock if unmodified)
Type of Engine, Cubic Inches: 364
Bore and Stroke:
Static Compression:
Piston Type, dome or dish (specify +/- cc):
Piston deck height:
Pistons fly-cut with valve reliefs?[ ] CC amount:
Rod type, length:
Cylinder Head Details: L92's
Manufacturer (specify casting number if factory or stock): Stock
Ported or Stock: Stock
Valve Sizes (I/E):
Port Volumes (I/E):
Combustion Chamber Size cc (very important)
Amount of milling (very important):
Flow Figures (I/E):
.100:
.200:
.300:
.400:
.500:
.550:
.600:
.650:
.700:
Head gasket thickness (very important):
Valve spring type, brand: (specify stock if unmodified)Lunati Dual Gold
Valve Spring Pressures (seat/open):
Rocker arm brand (specify stock if unmodified):stock
Rocker Arm Ratio: (very important):Stock
Pushrod length:Stock size
Induction Details:
Intake Manifold Type: Stock L92
Stock or Ported:
Throttle Body or Carb Size: Ported 87mm
Oversized injectors[ ] Size:
Fuel octane rating (very important):93oct
Exhaust Type: Long Tube
Primary Size: 1' 3/4
Collector Size:3'
Merge collector[ ] X-Pipe[ ]
Exhaust Diameter: 3'
Catalytic converters: no converters
Type of Muffler: 3' Magnaflow cut
Transmission Details: 4l60E/ servo
Type of transmission Automatic
Type of Clutch:
Torque Converter Stall: 3000-3200 circle D
Transmission Gear Ratios (specify stock if unmodified): stock
Chassis Details:
Rear Gear Ratio: 4.56
Rear Tire Size: 28'
Engine Management System:
Stock with aftermarket tuning
Aftermarket BS3, FAST, etc (specify):
Mass air sensor
no power adders,all motor!
