LS1 Oil pump died in truck. Time for a rebuild. Need some recommendations on parts
Hey guys.
Bought a 1999 new body silverado and it was running mint. Oils were all topped up and new oil change.
Dad drove it 4 hours to my new house and all went well truck ran mint.
I go to start it and the check oil light came on and then i was getting lifter bleed down. So shut it off and checked all the connections on the sensors and all is good. Restarted it and lifter bleed down was bad so i shut it off. No bottom end noise at all.
So i was planning on doing the following. I would like to make 350whp tunned
Engine:
Bore .10th
Federal Mogul Over haul kit pistons rings
Moroso Oil pump
Pacesetter headers Y pipe and a 3" exhaust
Volant intake.
Now i would like to pick up a set of LS6 heads for this build.
I need to know what cam do you guys recomened thats still good on gas and makes good power and torque.
Any links or ideas on over haul kits also.
Josh
