l92 cam suggestions?
i have an 05 tahoe just built lq9 with l92 heads, 07 up escalade intake, 90mm tb,42lbers full bolt ons nelson tuned running my old cam 224 224 569 runnin comp 928 springs and a 150 shot any suggestions on cam by the way its a 2600 yank converter thanks guys
l92s like a pretty large split, like 7deg or more....in a 6.0 i would do like 220/228 with high lift...in the lower .600s
personally i wouldnt go over 6*s on the split, reason being you'll run into ptv clearances, stay around 607/612 on the lift ;) i personally would stay around 235/239 which is pretty maxed out on the a lq9 with l92 heads :) thats a tight duration which you would need to widen the LSA to around 113.1 or so..
get with patrick G, he spec'ed both my cams with great success
+2 on a Pat G cam. 2 of my buddys are running Pat G cams
