I know a 34' radiator will fit in a 99-04 ish, Right? So my question(s) is, can i just install a 34' radiator WITHOUT having to use E-fans? What are the benefits of a 34' radiator from a 28'?
Thanks!
Thanks!
the 34 will fit fine, but im not sure if the shroud will fit.... if you notice there are already bolt holes on the rad support 3" outside your current rad on each side
bigger radiator = cools better
Hmm, Ill make it fit or find an ss with a fan shroud.
Probably going to order this one tonight,
2000 Chevrolet Pickup Ck Silverado All Aluminum Radiator ALL29623X23147 | GenesisAutoParts.com
also try looking for suv fan shrouds. my 03 esky has 34'' rad with pulley fan
