When swapping my 06 intake manifold and TB with the 08 NNBS ones should i use my 06 fuel Injectors or the new ones that came with the 08
guys ill be helping em with the swap....just dont like the idea of splicing any injector wires...could we just swap injectors and retain his originals from his 06'??
Just swap injectors if they're the same length, should be. Watch the OD of the orings, some of the newer injectors have a larger OD oring at the top of the injectors.
alrite thanks red...when we do the swap...will it be able to drive down to nelson's for the tune?like drivable w/o stalling etc
yah because im gonna try and do alot of things at once so Allen can tune everything once and only once till i add more parts that throw off the AF ration and stuff like that
are the injector tails different from year model to the one you have? if not just use your exsisting plugs?then again if they are different do what red mentioned just swap the injectors
personally i would use the new style but then again if theyre the same oh well use what you got :)
if u dont mind paying the extra cash here are some plug in play adapters i have used in past for similiar swaps
Wire Adapters & Harnesses - MINI DELPHI TO USCAR WIRE ADAPTER - Fuel Injector Connection
I spliced mine and they are fine, just don't do a hack job on the splice.
