SeaFoam?
Just wondering if anyone has had any good luck with using Seafoam? Through the intake/pcv or in the oil etc. Truck has a small lifter/valvetrain tick only at certian rpm and not all the time. Thought I would try seafoam and see if it makes it any better. Any one got any thoughts or experiance? Thanks
i'd run it thru the vaccuum line going to brake booster...i usually suck can in, turn it off, let it sit 15 minutes. Pour 1/2 can in gas tank, 1/2 can in oil. Let it IDLE 10 minutes. Change your oil, call it a day.
I've heard a few horror stories of it making a bearing go bad if driven with it in mixture...i do it right before oil change just to be safe.
We always add it through a vacumm port, and let it sit 10 minutes. Then we run it, and watch the rediculous smoke show! :popcorn:
