i need one, found out no one seems to want to cut my aluminum one.
i have a 2003 sss and doing the 80e swap so i need to shorten mine.
Precision Shaft Technologies, Carbon Fiber Driveshafts and Racing Shafts
This guy will make you a good one.
Also a regular cab short bed 4wd front shaft worked on my swap. If you are awd.
wow just talked to the guy and he does cut aluminum ones. seems like its the way to go.
wanted a carbon fiber one but not wanting to drop a grand just yet.
what are the pros and cons o having steel to aluminum?
No reason any driveshaft shop couldn't cut it. I had the one on my truck shortened.
i have called a few in houston and no one does it. they said they don't have the machine to cut aluminum shafts
