I dont get it?
hey guys I just installed the front portion of a belltech 4/6 drop on my silverado and the wheels are up into the wheel well. The outer portion of the tire is also touching the fender lip. I mean you couldnt slide a dollar bill under it, there is pressure on the inner fender and well from it just sitting. I thought for sure everything was going to fit based on some other silvys with the same mods. My wheels are 20/9.5 my tires are 285/45/20's. Shouldnt that work or am I too wide? Also I have not done the flip kit in the back. When that is dropped will it level it out and pull the front back up? Its not drivable as it is now...
What size tire should I put on to make it fit or do I need to pull the springs out or somthing?
ty
I had a 4/6 belltech drop and I ran 305/40/20s with no issues. I would think it will come up some when you flip the rear axle as well.
